Select Arcam Products On Pre-Order
Decibel
Chennai
Decibel is introducing a slew of Arcam products to it's clientele. Most of the products have been introduced recently into the market by Arcam and have been received well. We are also accpeting pre-orders for these products as they are available in limited quantity.
The rDAC
The rDAC is a well know product and needs no introduction. Using the outstanding 8741 IC from Wolfson Microelectronics, the rDAC produces clean sound across all frequencies allowing you to enjoy your music. The dCs technology allows you to connect a computer using USB, and the wireless using KLEER technology enables you to enjoy supreme audio quality from an iPhone, laptop, or just about any device that can use the rWave USB dongle. The rDAC retails for 29K and rDAC-KW (with wireless) retails for 36k
The rLink
The rLink is called "an affordable route to outstanding sound quality for a whole host of digital devices". The rLink is an S/PDIF DAC that supports both coaxial and optical inputs. Borrowing the same technology from the rDAC, the rLink uses PCM 5102 24bit DAC for exceptional sound quality. The rLink is an ideal upgrade for sound from set-top boxes, media streamers, game stations, old CD players, DAB radio tuners, and computers. Limiting inputs to just S/PDIF, Arcam has been able to keep the costs down for the rLink.
The rlink retails for 13.5K.
The rPac
If you use a pair of headphone for bulk of you music listening, you must look at the rPAC seriously. Meant for use with a desktop or laptop, the rPAC is a 24/96 DAC cum amplifier. Powered by an USB, the rPAC is you ideal audiophile companion when you are travelling so that you never too far from the music you love. The rPAC delivers clarity, depth, and a soundstage you have never heard from your headphones before. You may end up using your headphones more often that you intended. 'The difference between using one of these and your computers internal DAC is night and day', says WhatHiFi.
The rPac retails for 13.5K.
The rBlink
The rBlink is an audiophile Bluetooth music connection. Using the APT-X transmission system, the rBlink allows any Bluetooth equipped music device to quickly and easily send music straight to a HiFi system with stunning quality. Again borrowing from rDAC, the rBlink uses PCM 5102 24Bit DAC to convert music to a line level output.
The rBlink retails for 13.5K.
The drDock
With both video and audio connections, the drDock is an audiophile grade connection for the iPhone/iPod. Built using aluminium, the drDock is a sturdy dock that will gve you years of fun. Though it has it's own IR remote, the drDock can also be controlled by the remote of matching Arcam products. An USB connection allow both syncing and charging from a PC or a Mac.
The drDock retails for 18K.
For more details, please send a PM or email to <[email protected]> or to <[email protected]>
