Sound system (home theatre)
saidurme99
Dhaka, Bangladesh
My home theater sound system is comprised of Denon AVR-1911 and Jamo (s606 Hcs3 with sub210). I bought this system last year. i am ok with it's output but not satisfied. I can't find the reason or incompetency of the system. i need help from you guys.
Can you describe by what you mean by not satisfied?
Can you provide a layout of your room with the equipment?
How is the equipment hooked up together- block layout?
Have you done a speaker calibration with your equipment?
with thtpro's questions i want to add
SOURCE.....it is most imp..good source is satisfying even on cheapest set ups...imho
Essentially correct. I do not find any fault with your AVR and speaker system. What player do you have? What media are you playing? Downloaded AVI (700mb) will not yield any satisfaction, for example, as they do not have 5.1 sound. Try original DVDs/BDs (buy, borrow or rent).
