Speaker cables change for HT setup
Kolkata/Patna
Currently i am using Bandridge LC1159 for my HT setup and satisfied with the performance, though dialogue clarity from the center is bit on the lower side. Was contemplating on upgrading to Chord silver screen.
Will there be any noticeable change in sound quality? I am not looking to spend too much on cables.
It depends on your setup,you can go for it for the Fronts alone.. that too If you have a good Bookshelf or Floor Standers other wise its not necessary to spend the money.
Saran
