Speaker for Yamaha RX-V675
From a specifications point of view, the JBL sub will be an active sub and will perform fine. the 675 should be fine to drive the bose cubes - am not asking for the model since bose doesnt give specs for it. you will have to use your ears and intuition to balance it. adjust the sub volume to suit the cubes. and also ensure that at what volume level does the bose flatten out and dont drive it beyond that. apart from that in my experience yamaha and bose pair well
Can I use JBL subwoofer PSW-1200 and Bose cube speakers with Yamaha RX-V675
Does YPAO display the lowest freq response of the measured speaker after calibration?
If not use 200Hz crossover.. I have similar cube's from Ondia satellite, 3 inch fullrange speaker, after Audyssey calibration it detected 200Hz..
