Speaker Repairs -Sony
vardesh
mumbai
Hi All,
I have Sony bx333 bookshelf speakers attached to Norge 2030 amp .Nowdays the speaker does not sound good .might be some tweaking is required ,pls help me out is finding some speakers repair shops .i am located at borivali mumbai.
Plug in headphones and check the sound, if headphones sound good check the spkrs cable if no improvement Check if the speaker cone is damaged by removing the front grill, or the spkr sounds muffled, if so it has to be re-coned, take it to Lamington Road (near Grant Road station), there are plenty of speaker repair shops, may take you a day to get it repaired remember the re-coned spkr will not sound like the original, however if you give it to Sony agency for repairs it will be cheaper to get new spkrs
Make sure it's the spkrs that are bad before getting them repaired by connecting spare spkrs
Good Luck
