Speakers for 5.1 channel DNM amplifier 120W RPC
Rishabh Raj
Rourkela
I have 2 satellite speakers and two box ones the power output capacity is considerably different of both the types , the former ones produce high frequency sounds better where as the later ones vice-versa....
My ques. is that should i use those satellite ones as rear left and rear right and the the two box ones as front left and front right...??? :)
You cxan
Just locate a decent Cente and Sub then
I did similar thing with sucess..( it was assortment! Like JBL Control 1 Fronts , Supercheap Sony speakers as Rear ,a big kenwood as centre and sub by company called dynaquest
BTW to which source you are going to attach DNM ..the amp is good ( and do not go by quality report in another thread, I am sure it is DSE not DNM) BUT DNM DOES NOT HAVE ONBOARD DOLBY DIGITAL_ DTS Decoding.
To my DVD player..., u mean the source sholud be having the DOlby DIgital decoder..., i want to know if the decoder not being present in the amp. will hamper the audio even if it is there in the player......
