speakers for onkyo tx nr 727
noelsukhjitsingh
Ludhiana, Punjab, India
hi everyone I am going in for anew av reciever, i have zeroed in on onkyo tx nr 727. eventhough this is a 7.1 channel reciever i want to start with a 5.1 speaker system.Can anyone advise me as to the speakers i should go in for with a budget of approx Rs. 40000,
The best value for performance and quality is Boston Acoustics. You can lookup the Boston Acoustics Soundware XS 5.1 for a good satellite system with powered subwoofer.
Boston Acoustics SoundWare XS 5.1
Here is a bookshelf model if you want to go for it.
Boston Acoustics A 2310HTS Home Theater Speaker Package
PROFX sells POLK or KEF which may also appeal to you. You may require to stretch your budget for speakers. End of the day it all depends on what appeals to you and your budget.
Hope this helps.
From my experience, Onkyo may pair well with Polk. may require to stretch your bugdet for polk and also listen to the speakers and then decide.
Noel, I recently changed my Denon 1707 for a Onkyo 727. The speakers are all Polk and they really sound good for movies. You can see the speakers in my signature line. Polk might have changed the newer model naming though. I would recommend them.
