Speakers for onkyo
RajeshGoa
Goa
Was wondering is it good option to buy Bose Acoustimass 10 for onkyo TX NR 636
If not which speaker sets best choice for TX NR 636
Thx
Raj
That's one of good receivers i hear about. 3D and 4K upscaling. Secure for future!!!
Yes, it does go with AM10 series. One of very good combinations. Do check here, if you have not seen them.
Onkyo Bose Package 08
AV receivers from 4 to 8 ohms are supported. (and 100-200w per channel) So your NR 636 should fit in it. (Even AM6 supports it) Do check the manual of bose. It's clear there. If you cannot get it, let me know. I shall send you the manual.
