Speakers for Yamaha RX V 679
3rli
Hello Team,
Iam new to forum please suggest me good speakers Front Center and Surround please also advice SUB Woofer for AV. i will be helpful if you tell price for the same along with dealers in Bangalore.
Thanks for your Advice and suggestion::)
Based on the output specs of the AVR, you need to decide which speakers will go well....you need to also decide if you want floor standing ones or bookshelf or satellite speakers...all depends on design, size and performance....you need to visit dealers with your kind of music and decide which one appeals to you in looks, performance and ofcourse your budget.....all the best....your eyes and ears are the best deciders...
Thanks for your reply
Please advice on below
RTi A7 / A5 - FLOOR STANDER
Csi A6 - CENTRE CHANNEL SPEAKER
DSW PRO 550 - POWERED SUBWOOFER and PSW 125
thanks
Though the 679 may drive the RTiA5 better, I liked how the lows sounded on the RTiA7. If you already have the AVR, take it with you and listen to both the setups yourself to decide.
If your room isn't oo big, the CsiA4 could be good enough.
The DSW 550 is much better than the PSW 125, given that the budget allows
