Subwoofer repair in Bangalore?
Chaos
I have a Pioneer S-RS3SW subwoofer which does not turn on anymore. It is around 4 years old. The rest of the speakers which came with it are working fine.
Anyone know any technicians who do home service? The official service center is near Cantonment which is quite far from my place.
Home Service would be a challenge as Technicians would work in the comfort of their dens with all relevant tools....for all you know...it could be a simple fuse issue which you can replace...or dry solder issue....you can take it to a qualified repairer who repairs LCD or LED TVs....he can quickly check to see if the FUSE is blown or if there is a dry solder issue
I would suggest that you get it checked by the authorised centre. You could end up spending way more by getting it serviced by an unauthorised technician.
