Subwoofer Replacement
mvinoos
I have a Kenwood Subwoofer, SW-605. The speaker is damaged with the diaphragm suspension rubber broken into pieces due to weather, perhaps.
What would be the best way to repair this. I could not find any kenwood home audio replacements in india.
I thought of two options;
1. Try getting this repaired (Suggest, if there is any good place where I can do this)
2. Replace the subwoofer speaker. (This is 8" and suggest the best option/ brand)
Also, I found JBL having an 8" car audio subwoofer (GTO804), how is a car audio subwoofer different from what we use in HT. Will this be a good replacement option.
Thanks for your suggestions.
Vinoo.
