Check with "Avenue Sound" dealer in mumbai. i think they should have it.Thank you bro but i am not sure where will i find this in mumbai india. i checked even online its not available on indian websites
15000/- is not enough for a 5.1 setup.not even for a 2.1 Setup.F&D F5090 - this has got enormous bass to make movie-viewing pleasant, and speakers provide a reasonably clear output too.
For this amount you will end up buying a cheap sounding system and wont be a life long investment. Better buy a pair of Audio engine A2 for 15K less sound, less bass, but better quality and better details. Its os the best setup for music but as you need a 5.1 setup i believe this is for movies go for the sony branded or samsung branded setups, they will be atleast better than F&D
i have shortlisted two
edifier C6XD or C6 hcs5640
both have amps but which is better
and any particular model F&D u would recommed
moreover i would connect to my pc but at times i need to connect to my bluray player
