Suggest a 4K Projector and Suspended Screen
soamz
Dubai, UAE
HI, currently I have Epson TW8100 Projector and I use a basic screen got from amazon India few years ago.
Then AVR is Denon 2113. It says 4K support, but I haven't tested it yet.
I will go ahead and sell the Epson TW8100 Projector.
Looking to buy a 4K projector with a good screen available in India.
Kindly suggest!
Kindly suggest!
4k is a good option ,but you need to specify your budget for the FM to suggest.
As per my knowledge ,Optoma UHD 65/60 is the least budget which supports true 4K .Indian price of the model will be still high though.
The other few brands that supports true 4k are JVC, Sony which are high end budget pj & also Benq which budget may be roughly around 4L.
Epson on the other side has only supports 4k upscaling type projectors.
Kindly suggest!
You have very limited options in India when it comes to 4K projector, You may need to check Optoma UHD65/65.
if you're considering a projector upgrade for 4K/UHD content you need to make sure every link in your video chain must be compatible with HDCP2.2 & HDMI2.0.
Which means your medial player, Streaming box, AVR and even the HDMI cable must support HDCP2.2 & HDMI 2.0
Also its better to use Fiber HDMI cables if the distance between AVR & Projector is on higher side.
https://www.amazon.com/RUIPRO-Fiber-...keywords=UHD60
Kindly suggest!
A different suggestion.
Why not try a proper screen, good one. Branded or diy.
Because, yours is a full hd PJ. Make use of its full potential. Prices of 4K PJ are not saturated yet. Also, what is your sources?
Which screen do you suggest ?
Im looking for a good strong 120 inch and fixed screen.
I have all 1080p Blu-Ray, so I guess FullHD projector I will stay for now, and wait for next year for 4K projectors
For screen ,search in the forum, will get plenty of brand names.
Also check in the home theatre builds.
yours is full hd PJ. How much hours lamp used?
