suggest ICE for my new i-gen i20? budget 75k
vix41085
india
hello friends,
i want to install ice in my new igen i20. i dont want to change factory fitted head unit.plz suggest me speakers,amplifier,woofer,amplifier wiring kit.my budget is 75k.
hello friends,
The factory fitted head unit is just crap. I have i20 purchased last year and changed every ICE item from the car including the head-unit, speakers (factory fitted were just looking like papers on a ring :lol:) and speaker wiring.
My configuration
Pioneer 3200BT (US model)
JL Audio Front Components & back coaxials
Internal wiring..
The head-unit is actually 2-Din so there will be a gap with the center console. The shop in Bangalore where I installed in fact has a outer plastic casing which exactly fills up the gap and looks neat/good.
Hope this helps.
My configuration in my i20:
HU - Alpine CDA-117
Amplifier - Alpine PDX-5
Front Speakers - Morel Tempo components
Rear Speakers - Morel Coaxials
Wiring kit - forgot the name!
Subwoofer - Rockford Fosgate Punch - 10 Inches
Not sure about the options if you want to retain the existing HU. You may need to look at some amps which accepts line level inputs - I guess. Experts here may have some ideas.
If you are interested in a double din HU, there are a lot of options. Meanwhile you should have a look at the Pioneer DEH-80PRS CD Receiver - The specs are really good (intended for an audiophile on a budget)
