Suggestion for 55inch TV with best Picture Quality rate between 40000 to 85000
If you like to game and planning to purchase some new consoles, then you should opt for Samsung Frame 55" or else you'll be fine with Toshiba U7980
Thanks Jeetesh Kenobi. I see only OTT and HD Dish. Do not use gaming consoles. So for sports and fast action move without blur which is best. would you suggest or u7980 is enough
TataSky has 60fps broadcast .
It doesn't. Tata sky has 1080i 60 broadcast, which after deinterlacing is equivalent to 1080p 30. In 1080i, you only get half a frame at once (1920x540) and half the next one. So 2 frames make a full 1920x1080 frame (deinterlacing).
If you have found a way to get a 1080p 60 signal from Tata Sky, please let me know. I'd love to get 60 fps cricket broadcast.
I agree, they have 1080i 50hz and 60hz thats all
1) HDR\SDR Movies\Sports from OTT apps and DTH
2) Sports on DTH (Mostly football along with some tennis and some cricket)
which is the best tv under 100000
