Suggestion for Wireless Speakers(Bluetooth)
girish_sutar
Pune
Hey Guys,
I am looking for wireless speakers for my bedroom, objective being playing random music, just for casual listening.
Also if these would be available in Pune. Budget capped at Rs.10k.
Girish
Hey Guys,
Girish
Hi Girish,
Here's a link that is more like a pointer than anything else. I personally have not used these, so cannot comment on performance, but the specs seem to suggest they'll suit your requirements of casual listening just fine.
Wireless speakers
With prices under Rs6k, these fit into your budget with much room to spare!:D
Of course, there are many more options out there. All the best.
I'd suggest that you get this (Logitech Wireless Speaker Adapter, about 3.3K) and a good pair of powered 2.0 (or 2.1 if that rocks your boat) speakers with the balance amount. You can always use both items in some other application later. I think you'll get better bang for the buck this way, rather than going for wireless speakers.
I use this adapter to stream Internet radio from my laptop/tablet into my setup and it sounds pretty decent (as good as a pair of ordinary EP-to-RCA cable off the laptop's/tablet's 3.5mm jack). I have the BT Receiver hooked up with my amp.
sorry for bumping year old thread....i want to have the logitech device...since its not available in india anymore...want to get it from amazon....one problem is the power adapter. any local adapter will work with this ???
