Suggestions for Speaker Cables
johny747
HI,
Time to upgrade my speaker cables. I was reading reviews on Supra 3.4 & Van Del Hul.
Anyone using these, please update me with your views.
Suggestions welcome
Hi:
VDH are very warm and smooth-sounding cables, build quality is excellent, can be used without a doubt to tame a bright system. Other than that, can also consider Chord, very nice cables; the Carnival and Rumour could be bright in a forward-sounding system, but the Odyssey 2 is excellent.
I am using Supra classic 4.0 & are very neutral,musical with all frequencies.There was a good improvement over loose OFC cables.
What about Chord odyssey-2 cables. Pl. enter your valuable suggestions or opinions who are using it already.
Thanking You,
Sorry Gentlemen,
The Equipment will be Rotel RC 1072 = Denon PMA2000 = Jamo Concert 11(D870).
Do I need to Bi-Amp? I read a lot of conflicting write ups on Bi-Amping!
Supra & Odessy Users. Have you Bi-Amped.
I have used the Supra , But in MY SYSTEM , I did not like the sound. The VDH sounded good, try some cables in your system before making a call
The Chord are supposed to be good, but will make your Denon and Rotel combination more brighter.
For that setup, VDH is the way to go. What VDH you have in mind?
I guess what you meant was biwire!?!? - yes, that's always conflicting. You can safely consider single run of wires and save some money than going biwire.
Said that, I don't think biamping isn't conflicting at all. Biamping will take your setup to the next level.
@ vinod-sorry if i seem to be hijackin the thread....but how do you biamp?.i have an nad 302 and marantz pm5003 is it possible to biamp them to my wharf diamond 10.1 ?!!!!!!how do you connect the source(marantz cd6002) to both the amps??!!!!!
