Tanoy or Boston s1
JPS07
india
need help to know which speakers will suit best with my Denon AVR 1508 tanoy tfx or Boston xs 1 or boston S1
You need first to ensure that the speaker impedance is same or more than the AVR. This will ensure no overheating issues.
Matching Amps and Speakers - Do we Need to Worry?
Speakers which have a bigger set of drivers or cones will definitely disperse better sound around the listening area or room.
Speakers which can cover all or maximum frequencies between 20hz and 20khz would be ideal.
Speakers which have a sensitivity level of 88db and above will work better at low and high volumes...
Speakers whose Cones / Drivers are made up of better material will sound better...
These are basic parameters you need to consider....ofcourse budget plays a crucial role as it is what appeals to you in performance, looks etc....
Fortunately, there are reviews and videos over the internet which you can refer to and finalise the speakers which would work well..
