TATA SKY HD , Low Signal Strength
Nishabfss
Delhi
Hi Guys,
What should be signal strength on a TATA SKY HD plus box.
Also, what is important Strength or Signal Quality?
Signal Quality to achieve Quasi Error Free Value
Hi Guys,
Signal Quality is most important and to be precise need check Bit Error Rate (BER)
I feel for DVB-S2, ideally we should target to achieve the BER of E-10.
I was getting BER about E-04 level and was having a picture quality bad i.e. blurry on my AirTel HDR noticeable on SD channels like Zee & Sam.
Later we have reposition the DISH and then further gone for two different DISH for each Tuner of the HDR so that the drop with both Tuner simultaneously working has vanished.
Now I am getting T1 for E-08 to E-09 and the other is E-06 to E-07, the picture quality is feel ably improved on SAMSUNG 51E8000.
Still working on other Tuner2 to improve it further.
Normally people says that in Digital Signals there is no PQ difference once you get minimum Signal strength required for Display, but it is not True.
We need to achieve Quasi Error Free Level (i.e. BER below E-10 for DVB-S2) to get Better Quality Picture which is called as Perfect in digital terms i.e. FEC (Forward Error Correction) logarithms can compensate for a certain amount of errors to produce "perfect" picture.
Re: Signal Quality to achieve Quasi Error Free Value
I am getting fluctuating BER:
3.0E-7, 4.0E-7, 2.0E-7 all one after another..
Signal Level is at 143 for T1 & 147 for T2 for Tata sky HD Plus box...
I am non technical so have little knowledge about above
BER : E-07 is not bad.
Need to know which TV you have?
Also is there any specific channel where you face quality issue?
If so then be on the specific channel and check if there is a drop in quality.
By The way : also let me know the percent what quality graph is showing?
