Top earphones under Rs 3000
Insomnia
Chhattisgarh
Hi friends,
I want to buy 2 earphones each Rs 3k, one Basssy earphone and another overall sound quality. What are my options?Please help
Brainwavz M2 for the bassy earphones ...... Bass quality/quantity both in good balance, warm pleasing sound.
Sennheiser Cx500.
I use the CX300 and they are really great not too boomy bass and good isolation. Ive been using them for more than 2 years now (they have a newer design now) without any issues. Ultimate Ears have got great reviews as well.
Sennheiser Cx500.
Most reviews i read the brainwavz beats sennheisers, shures, big brands in the same budget by quite a margin.
I own the brainwavz m2 and if bass is something you are looking for these are tough to beat for the price.
I beg to differ. The Brainwavz M2 are indeed good IEMs but the bass is not its forte. Something like the Xears TD100 - III would it easily in the bass department( and I am not talking about boomy uncontrolled bass)
Since the OP has mentioned two IEMs in the 3k budget, I would suggest looking at:
Brainwavz Pro alpha for bassy sound and something like Soundmagic PL30 for balanced sound.
Are you talking about these
xears_Turbo_Devices_TD_III_V2_PRO
the price is steep @ 5600 + shipping and customs
Purely for the sound are they worth the money from vfm point of view ? Build quality/classy wood does look awesome though.
They have a permanent coupon KLANGFUZZIS, which makes any IEM available for 30 Euros. The shipping is 8 Euros irrespective of the no of IEMs you buy. Purely for sound, I like them a slight bit more than M3. Build quality was not it's forte, but the newer "textile" cable (cloth covered) looks better so far. Have not spent much time with my new TDIII v2 yet. Can comment further only after some time!
In case of RMA, all you need is to cut the cable and send a photo to Thomas - personal experience ;)
BTW, iaudio! Experience EX200 is good too! Does not have an attractive signature like TDIII, but almost the 'correct' bass right between Bullet and TD. Open sounding (Been a long time since I've heard an open sounding Xears), good imaging, balanced overall. Not that I want you to buy, but... :rolleyes:
