Toroidal mounting hardware
talespin
Delhi
Is there any place online where i can get toroidal mounting hardware?
I want top metal plate, round rubber plate, 5mm bolt
Thankyou
It usually comes with the transformer. The top and bottom plate, rubber washers, central bolt and nut. Maybe you can get some from the manufacturer like miracle bangalore.
U can use insulation washers available at electrical shops or buy backlite sheet and cut as per ur size.
One has to be sure not to mount a toroidal transformer in such a way that you created a conducter loop with the chassis.
Nut-Bolt from hardware store, ask for SS or chrome plated. Just 5mm more length than transformer height is okay.
Rather than round plate buy round flange of lesser diameter from machine shop, drill central hole or 3mm thick 2" wide iron strip with hole in center from welding shop. Length of strip lesser than diameter of transformer. Get its rough edges smooth and burr removed on grinder at same shop.
For rubber washer, piece from car tube works, get cut round from cobbler. It works and beats temperature of hot running transformer.
Good luck, take care keep all metal surfaces electrically isolated from surrounding.
