Upgrade from Denon 1707
John
Hi guys,
I am looking to upgrade my AV receiver from my current Denon 1707. It has served me well for many years. I am going to use the same speakers (see sig) as of now. However, I want to add 2 more speakers (rear side), to make it a 7.1 system initially. May add a sub later.
I am looking at Denon 3313 or X2000. Someone told me the X2000 has problems. Please put in your recommendations.
I am willing to look at other brands like Onkyo, Marantz, Yamaha, etc.
Thanks in advance.
Hi guys,
Thanks in advance.
Consider Denon X 3000/4000, if you have a good budget.....
Also instead of using surround back channels, try them as front wide speakers with Audyssey DSX mode... This also needs some space in your front walls....
Thanks,
I was looking up Ebay GEB and the price difference is quite large. For example, Denon x3000 can be had for around 64k or lower on Ebay GEB. Coupled with a step down transfer for 750 W, for around 3-4K, it is a saving of 20 K compared to the 90K+ pricing in India. :D
Any other sites to get AV receivers cheap and getting them imported via iShopInternational?
Thanks!
Thanks,
Thanks!
Why dont you consider Marantz SR 6008 ? i'm upgrading my Denon 1612 and almost decided on SR6008. I have a good deal (65K) from Hifimart for 6008
Marantz SR5008, SR6008, and SR7008 Receivers Preview | Audioholics
Thanks,
Thanks!
When you want to buy an High end AVR in India, I think it is a mistake.....When you know the pricing is FAIR/BEST middle east, Europe & US, try every means to get it from there, of-course you will have to risk the warranty.....
Buying an high end AVR in India, is like day light robbery..... Ridiculously priced...:mad:
I would never buy any AVR from India... Will try all my best to get it from any of my friends who work/passby Middle east countries.....
We already have the limit of 35K... Anything above am willing to pay the duty @ customs and get it....But thatz just me...
me too, I was with these cables from day one. The system does sound good though.thanks
nqpSam
@ John - Emotiva? If you delegate the front three channel duties to an outboard amp, the remaining channels can be powered by your AVR with flourish. Any good power amp should work I think.
Thanks Shuv. Never had this in mind, now has put me thinking. Can I add a power amp to the Denon 1707?
Meanwhile, should I get an AVR from the US like Onkyo 818, how much power should the 220 volts-110 volts step-down transformer be?
If you AVR has pre-outs, then you can add the power-amp.. But looks like your model doesn't have Pre-outs...
Try to get AVR from Middle East/Europe countries....Most of the models have 220 ~ 240V ratings & you will not need a step down transformer......
If you are thinking abt getting it from US, then try the Dual voltage models...You will not need any step down transformer..
220-Electronics.com | International Relocation Electronics Specialists
Yamaha | Denon | Dual Voltage Audio Video receivers, World Wide voltage 110-220 volt AV Amps
Audio Video Receivers | 220volts Audio Video Receivers | 240 volts Aud
Thanks bud, as of now, the e-commerce sites seem to charge a premium for 220 volt receivers. So the options are to 1) Look for a good deal here or 2) Buy a 110 volt model from the US and use a step-down transformer.
I think you should wait for few more months. New receivers will be announced soon. You will be glad if you wait.
Thanks bud. Any specific models on your radar? Also, I am always afraid they will be priced sky high.
In case I wait, I will go for a PJ upgrade.
Another question bugs me a lot. A lot (well all) of these mid AV receivers are made for multi-rooms which I am not going to use. Is there a good receiver for single room use? Hope the question is not dumb :confused:
