USB 3.0 adapter question
GeorgeO
Cooke Town Bangalore
Folks
Cana get a USB 3 adapter locally to install on my computer to speed up data transfer rates form a USB HDD? If yes, what might it cost?
TIA
Folks
TIA
If its a desktop, you can get a USB 3.0 adapter and use it.
Folks
TIA
I bought one recently and have it installed on my desktop. The one I purchased was a Transcend one and it costed me around Rs 1200.
As mentioned you can use a PCI card (I too bought one). However, they say long term usage of the Pci slot is not good for the desktop, some experts can verify.
^^ Thats an absolute FUD. @George you can opt for a PCI slot USB 3 card for 2,3 USB 3.0 ports. Something like THIS
... they say long term usage of the Pci slot is not good for the desktop, some experts can verify.
I don't know who they are! PCI slots are there to be used. You can even buy very expensive and hugely fast solid-state storage that slots directly into PCI.
The only thing I might have heard is that PCI USB3 might not be as fast as native USB3 --- but, if the MB doesn't have it, that not's something to worry about, and if it does, the question wouldn't arise anyway!
What is FUD? I have the PCI Slot Card for more than 2 months now and don't find any issue at all.
2 months!!!, my C2D system used as my HTPC now has a network card to it PCI slot for more than 4 years now ......
FUD... already explained .... :)
