USB Audio Port
venkyts
I have a FM radio with USB port for audio files. However of late it is not detecting pen drive or any such device. The machanics are not taking up as it is very small set and they do not have time for it. Can anyone help me restore it please?
Model nos and photoes please? have you checked with different usb drive and also different set of MP3 files?
Open up the box and look around the USB port from inside if you can make out any physical damage.
Otherwise, since its a cheap Chinese set, it is a use & throw machine.
Complete USB audio assemblies which are ready-to-fit to amps can be bought for less than Rs. 250/-. That includes a remote and a small LCD too. Check your local electronics market for it. Should work out cheaper than repairing your old set.
Saket
