Using ChatGPT to create Spotify playlists
ssf
Mangalore
Open the ChatGPT app.
Click / touch '+' before the prompt.
Go to Explore apps
Select Spotify - Select connect
You will get spotify in your prompt
Go ahead as ask ChatGPT to create playlist of your choice of singers / songs.
I asked it to create a playlist of a few singers but songs that I have not heard before ..
Drawbacks:
It might take time depending on the task. Sometimes it might fail. I had to ask it to try again and it succeeded.
Just one of the few things that can be done on ChatGPT other than asking it questions.
ChatGPT is interactive. You can ask it to make changes to the playlist as per your requirements. I have asked it to create 2 playlists of 50 songs each so far and it has done that successfully.
You can also ask ChatGPT why it did not create a playlist in Spotify and it will tell you.
I tried it, apparently cannot edit a playlist but can create a new one .
Go to Explore apps
Drawbacks:
Just one of the few things for mais informações that can be done on ChatGPT other than asking it questions.
Yes, I tried it, but it seems you can’t edit an existing playlist—only create a new one.
