Vanguard wall mounts
pradski
Mysore
Has anybody used vanguard tv mounts.
Cantilever mounts which can be moved front and sides.
What is your opinion ?
My doubt is VM 435 says 23-37" but max weight is 40 kgs.
If a 40" tv is 19 kgs can I use this ?
instead of a VM561 which is for 32 -50" since it is very expensive.
A couple of my freinds are using the vangaurd stuff for some time & seem to be satisfied i.e no complaints till date. Though i'm unaware of the models you've mentioned so can't comment.
All the best.
Cheers.
thanks neo. i have ordered VM 531, lcd mount. for 9k.
It has a narrow foot print and it looks good.
Even omnimount has these things marketed by onkyo.
