Velodyne vPulse compatiple with Nexus 4 Android phone?
sukhjinder
New Delhi
Folks I need some help with buying some bass biased Android compatible IEMs.
I'm considering buying Velodyne vPulse IEMs. Following are my concerns
1) I have Google Nexus 4 Android phone. Will the IEMs be compatible with it? Will the play/pause and volume control buttons work? I will be ok even if just the play/pause button works.
2) I have used SoundMagic E10M and E10S. Both the IEMs are loud as compared with other ones I've used. I'd like to know if vPulse IEMs are also louder than standard ones.
3)Are they heavier than E10Ms?
Thanks a lot!
