Versatile Universal Remote Control.
Decibel
Chennai
Comprehensive & Versatile Universal Remote Control!
[IMG2]http://img528.imageshack.us/img528/4186/redeye.jpg[/IMG2]Calling this a remote control is an understatement. Convert your Android, Kindle Fire, any PC/Laptop, iPhone 3G/3GS/4/4S, iPod touch, or iPad/iPad 2 into a universal remote control for all devices.
RedEye uses standard Internet technologies like TCP and HTTP, and sends around information in XML documents. And now, RedEye can assign an IP Address to each device which means that all your devices can communicate with RedEye, and all the devices can be controlled with a basic web browser.
At the entry level, RedEye is a small dock you connect to the device. At a more professional level, RedEye Pro comes equipped with a wide array of physical connections so that it can work with devices that receive infrared commands as well as those that communicate over a serial port (RS-232), using sensors, relays, USB ports, Ethernet, WiFi, and more. This means any device can be connected to your control system. You can just tap a single key to watch a movie or listen to music. All the devices will be switched on, the room ambience will be controlled, and the movie will start for you.
With the new IP based control system, you can view what movies are available on your home server from your office just before you leave for home to set your mood.
