Vinyl Enthusiasts
Its nice.
But it is priced rediculously!
I have created couple clocks for myself using vinyl and a clock "movement" mechanasim which you will get for around Rs. 70-80. Its a small black box of the size of a match box - little bigger which has the motor that spins the hands.
You can also get clock hands around Rs.100 or make your own as per your liking using cardboard or any material you like.
However if you want ready made then you should be able to get similar ones much cheaper elsewhere.
But there is a different pride and joy if you make one yourself and hang on your wall. DIY spirit!
Cheer and thanks for sharing!
Rohit
