VLCPlayer on XBox 360...
asatsi
Pumbai
Is it possible to install a media player like vlc or any other on Xbox 360 that supports the more popular divx/ripped formats?
Thanks,
Satish/
No you cannot download any player which will play everything on xbox 360. You have two options, buy a raspberry pi and use it as a media player, second option is if you have a windows pc which is powerful enough of encoding on the fly, then you can stream the encoded stream to your xbox. detail description
