S srujan21 New Member Joined Aug 15, 2012 Messages 16 Points 0 Location INDIA May 16, 2013 #1 Hello , planning to buy a water purifier, suggest between Aquaguard and kent , and beside filtering do we have any taste difference between UV AND RO ?
IndianEars Well-Known Member Joined May 18, 2008 Messages 1,381 Points 113 Location Mumbai May 16, 2013 #2 Where Are You Located ? Do you receive Municipal Water supply or from a well ? A decision on whether to buy an RO filter and a simple UV filter will depend on that. Whether there will be a taste difference in the purified water will also depend on the type of water you are receiving .. Last edited: May 17, 2013
S shiny star New Member Joined Mar 27, 2015 Messages 1 Points 0 Location mumbai Mar 27, 2015 #3 i would suggest kent. have been using it myself since two years now.
S shiny star New Member Joined Mar 27, 2015 Messages 1 Points 0 Location mumbai Mar 27, 2015 #4 Check Kent's Water Purifiers at KENT Water Purifiers in India for Homes & Offices - RO+UV+UF+TDS Technology
S shiny star New Member Joined Mar 27, 2015 Messages 1 Points 0 Location mumbai Apr 1, 2015 #5 rujan hope by now you must have bought a good water purifier for yr home........
