WD40 - How efficient it is for Turntables?
audiohifi
Kolkata
Is WD40 an efficient lubricant/oil that can be used in certain components of the Turntable?
For instance the Tonearm end and inside the tonearm where the headshell fit in,or the RCA Connectors or any other components?
WD 40 is not a lubricant.
Tonearm bearings are supposed to run dry, any lubricant or oily substance there shall attract dust and gum up the bearings.
Contact points such as cartridge pins, sled and h/s contacts, RCA plugs should be treated with a dedicated electronic contact cleaner such as DeOxit.
I agree Deoxit is better than WD40.
Q: WD40 - How efficient it is for Turntables?
A: Depends on where you use it. It is derusting,cleaning agent but not for lubricating delicate bearings and levers on TT
