Which 5.1 channel amplifier is better .... abt the specs..
Frankly this is a very limited question.
What speakers are you looking at?
Which brand are you looking ?
Which Models?
What is your room size?
Are you looking at Blu-Ray?
These are just some of the questions that YOU have to answer before we can provide any meaningful information.
Forget the use... and this answer will not answer your Q as to which is better.
Your question is about power. Bulldozers have power, more than many mercedes put together... but that doesnt help.
Distortion is what is the limiter. compare the THD of both at their rated power and you will know the difference.
About which is stronger or weaker, I dont know, and apart from the above explanation, you will have to get in touch with an electrical engineer....
KD
Whether it delivers 60w at 8ohms, doesnt give the entire picture. It also depends on how much current it delivers to the speakers for those transients.
