Which cable and how
drkaushik
Siliguri
I have a LG 32 5500 LED tv. My comp's CRT monitor is out of order.
How can I connect my TV as the monitor before I get my new monitor?
Thanks in advance.
Thanks in advance.
Most of the TVs have the same monitor input socket, check it and you can use the same CRT monitor cable to connect it. I have the same input in my 6 yr old Sony Bravia V series 32" and also the latest generation LG LM6690 series 42".
Same cable. Similar port (RGB IN PC).
If your PC has HDMI out, well.. you know.
