Which CD Player for around Rs.50K ?
Shivam
Uttarakhand
Can you recommend a good sounding CD-Player for around USD1000 which is available in India and if possible a dealer for the same ?
I was looking at models from Marantz, Rega, Cambridge Audio and Cyrus but couldn't decide.
As a former Arcam owner, I'd highly recommend the Arcam CD17 (I owned the CD37 which is fairly similar) in your budget. The Cyrus is a close second but it depends on the rest of your system as it may be too forward sounding if not balanced properly.
Where in India are you based? I am sure fellow members would know of dealers in your specific area.
you can consider ARCAM,REGA-APOLLO,Musical Fidelity
For 50K dont get marantz they dont have re-sale value
but they are good in quality
Has anyone other than whathifi reviewed Audiolab.
Looks strange that their Five Star product is hardly reviewed by others.
I have a warm sounding amplifier and speaker setup with not very good bass performance. I need a CD player that has detailed and sweet sound with good low frequency response.
I have used Marantz earlier but hated it due to mechanical noise from it when the disc was spinning. It was especially irritating on playing Bach, Chopin and some other composers with not too loud passages.
I am keen Rega but can't find a good dealer in north India. I am situated near Delhi.
@srramanujam
They were just released in the UK and European market. Reviewers in the USA, Canada and other places may still be waiting to get their hands on them :D
I have seen an Audiolab player in a shop in Delhi but never got a chance to hear it.
@Shivam
The newer Audiolab 8200 series is in a different league than the old 8000 series. You will not even get an idea of the newer 8200 series if you audition a 8000 series cd player from Audiolab.
Its just the cosmetics were same between both series. But the internals were completely different.:licklips:
One more advantage with Audiolab 8200 series CD players is you don't need to think of an external DAC later. It comes with Asynchronous USB and other digital inputs.
The 8200 CDQ model has a pre-amp too to be connected directly to a power amp.
How are the NAD cd-players compared to audiolab ? Has anyone done a comparison of audiolab with NAD or Rega or some other common brand ?
Just stumbled upon this one. Thanks guys!! This means I need not invest in a reportedly "noisy" sounding sound card like Xonar or another budget DAC that wont take me there ....
I will budget for this one in the next few months. :)
An All-In-One source with choice of SQ to play with in the filters is the height of convenience!! :clapping:
Good think I did not spend on Xonar or another budget DAC yet. :ohyeah:
I am not sure where you got this idea about Xonar being noisy. I have just completed an Audio PC with Xonar STX. Played it through a Arcam rDac, and believe me it beats nearly every CD player I have heard. This includes all NAD and Marantz players, Creek, and even the Primare. I am writing a detailed review, but suffice it to say that I have never heard the three dimensionality and clarity that I heard with the STX/rDac combination. The STX is completely shielded and is not affected by any of the electrical noise within the PC. Using ASIO and a simple kernel level player such as cPlay, the combination can give a run for it's money to any CD Player within, I would boldly say, around 75-100K. What really pleases me is that I will get the same sound irrespective of how many times I play the song.
As I mentioned sometime ago, the life of a CD Player is limited, and manufacturers would find it difficult to justify the investment needed for high quality and innovation. If you notice, there are only a few players left in the market who make serious CD players, and this number will dwindle. In the last 12 odd months, software companies have seen a 20% drop in the sale of CDs and they would start making alternate plans for the distribution of music. A PC provides a dual advantage of being completely digital, and also a CD player with an < 2000 optical drive. I will be buying CDs as long as they are available, but using only FLAC versions for my use.
I am sure many would read my words with a large amount of skepticism. For me, the choice was an expensive CD player or a adventurous attempt at using a sound card and DAC. One of the best music delivery I have ever heard in my life was at Audire and that was through a DAC with the Marantz CDP acting as a transport. I am quite happy that my adventure was successful.
Cheers.
Cheers.
Well it was reported to be "noisier" than a cd5001 by a Bangalore forum member a while back in another thread.
Now you put me in a quandry. should I ? Should I not, should I? .... :mad:
Been postponing this since a year now ... :o
It can be abt sound coming from analoge out.I can say that my xonar D2X too has better digital output as I get almost nill noise from it connected AVR(than connected to DVDp).
I planned to use it only for analogue stereo out, so thats the problem. the 9K on Xonar could pay my customs duty in large part. While preamps and Power amps can be DIY'ed, DAC's are a different matter altogether.
Think I will drop the Xonar plans completely.
