Which one ?
mick_ralte
Aizawl
Hello Guys.. i need your advice on choosing front and centre speakers?
Pioneer SP-C22 or Polk Audio TSx150C
Pioneer SP-BS22 or Polk Audio TSx110
Please , also any options other then the above mention ( in that price range)
I have taken a Demo of Pioneer Bookshelf speaker (BS22 LR). Price is about 15K per pair.
It has got a 4" woofer and 1" twitter, Sound is impressive. But you cannot wall mount it as the woofer port is at the rear.
Other one is also a good brand but I did not take demo.
Good luck man.
Hi Mick....
Based on your budget and requirement, you need to audition the models you like and decide for yourself as you are the end user.....both models are good.....
Have you auditioned the speakers? Generally Pioneer have a laid back sound signature while Polks are brighter. Pick the ones that suit your taste.
MaSh
