Which USB powered soundbar?
gobble
Hi Guys
I am about to buy a usb-powered soundbar for my computer. My requirements are low profile tucked under monitor, no separate 2.1 subwoofer but decent bass and midrange, not thin sounding but full-bodied vocals at least.
I see options like this on Amazon - Creative Stage Air 20W
What do you guys recommend? Budget less than 6K. I dont want bluetooth only SB, I need wired input.
Hi Guys
Creative Stage Air should be good option to consider, I have not used it personally, however I have been using Creative SB Roar for some time now and very happy with the Product performance and build. Looks like Stage Air should be on similar line with better configure.
Any specific reason why your not considering powered bookshelf speakers?
