Which used AVR pairs best with ELAC DB63s for a bedroom projector setup?
heretobuyanamp
Noida
I’m currently putting together a setup for the master bedroom and I'm running a JMGO UST projector paired with some ELAC DB63s (and I might add a center later).
I need an AV Receiver to tie it all together, but I want to make sure I get the right one.
Here is what I’m looking for:
  • HDMI ARC is a must: I want the single-remote convenience for everyday TV watching.
  • Good Current: The ELACs are 6-ohm and a bit power-hungry, so I need an amp that can actually drive them properly without sounding thin or muddy.
  • Room Correction: Need decent calibration (like Audyssey) to keep dialogue clear at lower nighttime volumes.
My budget is around ₹25k - ₹30k. Because of that budget, I am absolutely open to buying a pre-owned/used unit to get better quality.
Which specific models from Denon, Marantz, or Yamaha should I be hunting for in the used market? Any hidden gems I should keep an eye out for?
Thanks in advance for the help! 🙏
