Wiimpro connection
Phani24
Vizag
How to connect wiimpro to norge1000 concerto gold.Please advise. Norge has 3 inputs. Tape,Aux and dvd.
Phani
Just connect audio analog out from Wiim to any of the three inputs on Norge. Make sure the volume is set to minimum when you play for the first time and then adjust according to your preference.
Phani
To do on WiiM Pro in the WiiM Home App:
1. Set output to line out
2. Change Volume option to fixed output
3. In the fixed max volume which is set to 100 as default, reduce it to 80.
4. Connect its analogue outputs (RCA output sockets) to any of the three inputs on the Norge amp
Control the volume on the Norge.
it has 5v power supply adapter. Csn yiu suggest the plug to connect
