Yamaha RX-473
Gaurav02
Jaipur
Hello,
I've Decided to Buy Yamaha RX-473, Could you please Suggest Compatible Speakers For the Same..
I have Samsung 51" Plasma and a Blu Ray and i want to buy to connect the same into it.
My Budget is between 40 000 - 50000 Indian Rupees [Including the Budget of Speakers, Speakers Brand is Not Decided Yet] Cud Extend 4000 - 5000 More For Best..
Ill Place the System in a Mid Size hall..
I Know Im Going The Other Way Round.. Shud've Chose the Speakers First.. But I Want Good System thats y Chose the System First..
Also Shud I Purchase The AVR in B&W or Shud I Purchase it in Grey..
Also From Where I Can Get It At Cheap Price..
I Live in Jaipur Rajasthan, Please Suggest and Advice..
Thanks & Regards
Gaurav,
You best bet would be to take a trip to Delhi (should not be very far from Jaipur). There are lots of audio-video shops in Gurgaon/Delhi where you could check out speaker options. Most of the AV shops should carry a Yamaha receiver; thus you would have a fair idea of what the speakers should sound like in your system. Listen to a few speakers and figure out something that you like.
I would always suggest buying with B&W. Saves the day incase some problem crops up.
Best,
APK.
Do you have any idea how much does it cost ?
On Net It is of approx 36 K ..
Is it available in lower amount than this..
match yamaha with warm speakers like wharfaedale or like.....
buy a pair of fronts only..bookshelve/fs....first.buy others later when strong in budget...
I am afraid, not always good way to pair with warm speakers.I have Tannoy with RX-V667 & fine details are easily misssed. Yamaha AVR are not bright now days & pair it wisely.
I am afraid, not always good way to pair warm speakers.I have Tannoy with RX-V667 & fine details are easily misssed. Yamaha AVR are not bright now days & pair it wisely.
So Which One Do You Think Is Good These Days And Easily Available in Indian Market..
