Setup 5.1 Home Theater in Living room
sarwan
chennai
Hi All,
I am planning to build HT with below configuration.
Room size 22×8
Three doors ,three windows with open type kitchen
Configuration
AVR Arcam 10
LR. monitor audio bronze 500
Center Wharfedale Diamond 12.C / KEF q650
Subwoofer SVS /Rel
later will add the rear speaker
Is power amplifier required. Can you suggest to me for better combination speaker
Saravanan
Chennai
Hi All,
Room size 22×8
Configuration
AVR Arcam 10
Subwoofer SVS /Rel
Saravanan
Chennai
Hi Sarwan,
Welcome. Wishing you the best in your journey.
The equipment list is impressive.
Only tweak i'd make is to stick to MA Bronze for centre channel, too.
I have a couple of rungs lower MAs and even that centre rocks. Despite being only a two-way, the Bronze centre should do you well.
So, do consider that.
Am, however, worried about the room dimension and the associated things you have said.
1.22*8 is kind of too narrow to get a decent sound stage.
You'll have to treat the 22 wall a lot for good sound, overall.
2. Not even the best subwoofer money can buy can pressurise this kind of space with an open kitchen. You'll have to find a way to manage bass, unless all use cases are near field.
3. The three doors and the three windows will bring problems of their own.
But please dont get disheartened. Maybe if you could share your room diagram, more knowledgeable FMs could pitch in with ideal solutions.
Warm regards
Hi All,
Room size 22×8
Configuration
AVR Arcam 10
Subwoofer SVS /Rel
Saravanan
Chennai
Are you sure that it's 22x8 ?
For what will it be used more ?
Movies or music ? Percentage ?
