Understand Different Types of Movie Rip Tags
kooldeep
Haryana
Code :
CAM (Camera):
A cam is the lowest and worst quality source of movies. At Junkies, we try not to introduce cam URLs. A cam is a rip usually done with a digital video camera by someone who made a copy of a movie by sitting in the back of a theatre. The camera often shakes, and shadows of people's heads are often seen. Sound is taken mostly from the onboard microphone of the camera, and especially in comedies, laughter can often be heard during the film. So the picture and sound quality are usually quite poor, but sometimes we're lucky, and the theatre will be fairly empty and a fairly clear signal will be heard.
Custom. Subbed:
A release can also be custom subbed. For example, Dutch subtitles were added to this rip: Mission.Impossible.III.2006.Custom.NL.Subbed.NTSC.DVDRip.AC3.Xvid-XvidsNL.
DC (Director's Cut):
A director's cut is a specially edited version of a movie that is supposed to represent the director's own approved edit of the movie. It is often released some time after the original release of the film, where the original release was released in a version different from the director's approved edit.
DivX Re-Enc:
A DivX re-enc is a film that has been taken from its original VCD source, and re-encoded into a small DivX file. Most commonly found on file sharers, these are usually labeled something like Film.Name.Group(1of2) etc. Common groups are SMR and TND. These aren??t really worth downloading, unless you??re that unsure about a film u only want a 200mb copy of it. Generally avoid.
DL (Dual-Language):
Means that the DVD contains more than one audio language.
DSR (Digital Stream Rip):
Recorded from Digital Satellite, quality is similar to PDTV.
Dubbed:
If a film is dubbed, it is a special version where the actors' voices are in another language.
DVB (Digital Video Broadcast):
The standard for direct broadcast television in Europe and the US Based on MPEG2 Compression.
DVDRIP:
A DVDRIP is taken from a retail DVD that you can buy. However, most are released on the internet a few months before you can buy them. DVDRIPS are high quality, as you would imagine. Usually ripped to DVD-5 (Single Layer) format. DVD Rip quality is usually very good. THE BEST OF ALL!!!!
DVDSCR (DVD Screener):
The same as a screener, but transferred off a DVD. The ticker is not usually in the black bars, and will disrupt the viewing. If the ripper has any skill, a DVDscr should be very good.
Extended:
Sometimes movies are released again on DVD because now the movie is extended. They have put back deleted scenes. For example, E.T. was produced first in 1982 and years later it was brought on DVD again, but now digitally remastered and extended.
FS (FullScreen):
Aspect Ratio Tags.
HDTV (High Definition Television):
For TV Rips. Digital recording from a source stream at a bitrates from 19,39mbps or higher.
iNTERNAL (iNT):
An internal release is done for several reasons. The most common reason is because it has already been release before, and with iNTERNAL in title, the release won't be nuked. It happens quite often with DVD's. Also lower quality theatre rips are done iNTERNAL so not to lower the reputation of the group.
LiMiTED:
A movie is LiMiTED when it has a limited theatre run (in less than 300 UK theatres, or in less than 500 USA theatres). Mostly smaller films (such as art house films) are released as limited.
MULTi / MULTiSUBS:
When there are multiple languages or subtitles.
NL / NO / DE / IT / EN ... (Language Codes):
The language of the movie and the language of the subtitles can also be mentioned in the release name. Sometimes the language is fully mentioned in the release name, such as DUTCH, NORDiC, GERMAN and iTALiAN. Sometimes it's shortened, then the ISO standard country are used, the same like for net domains, for example: NL (Dutch), NO (Nordic), DE (Germany), IT (Italian). For the full list, click here.
Nuke:
A movie may be nuked because of a bad rar pack, a missing rar file, the movie being mislabelled, or for simply horrible quality.
PDTV (Pure Digital Television):
For TV Rips. Other resolution digital recordings from source streams at a bitrates of 10+mbps or higher.
PPV (Pay Per View television):
Pay television programming for which viewers pay a separate fee for each program ordered.
PROPER:
A group adds Proper to their release if they believe they released the best quality version of the movie the fastest.
Rated / Unrated:
Rated means a movie is censored, unrated means uncensored.
R5:
This is fairly new movie format. Basically the same as DVD Screener - this kind of release is legal DVD released in Russia to decrease the level of pirated movies in this country. Retail is rushed out by the studio, so there is little to no cleanup of the film after the telecine process. As a result, you can see some scratches, hairs or other mess on the picture, but you will hardly notice it while watching. External English audio is often used, as these are supplied with Russian sound by default.
READNFO:
When something important is mentioned in the NFO or as a replacement for PROPER.
Repack:
If a group releases a bad rip (Nuke), they will release a Repack which will fix the problems. It's similar to PROPER but then done by the same group.
ReRIP:
A previous rip was bad, now it's ripped again properly.
SCR (Screener):
A screener is taken from a VHS tape that is used for promotional use, such as award shows. Depending on the equipment used, screener quality can range from excellent if done from a MASTER copy, to very poor if done on an old VHS recorder. Many times the screen contains a "ticker" (a message that scrolls past at the bottom of the screen, with the copyright and anti-copy telephone number).
SE (Special Edition):
Like the name says, it's a special DVD edition of a movie. Often special editions contain extra material like trailers, interviews, and making-of.
SDTV (Standard Digital Television):
For TV Rips. Digital recording or capture from a source stream at any resolution with bitrates under 10mbps.
STV (Straight To Video):
These movies were never released in theatres, but they were immediately released on video/DVD.
Subbed:
If a release is subbed, it usually means it has hard encoded subtitles burnt throughout the movie.
TC (Telecine):
Telecine are rare because the equipment used to make them is expensive, it is a digitally copy from the reels. Sound and picture should be very good.
TimeCode:
TimeCode is a visible counter on screen throughout the film.
TS (Telesync):
A TS movie is usually capped from a digital camera just like a cam, except it uses an external audio source (most likely an audio jack in the chair for hard of hearing people). A lot of the times a telesync is filmed in an empty cinema or from the projection booth with a professional camera, giving a better picture quality. Quality ranges drastically, from almost that of a vhs tape to a really bad cam, check the sample before downloading the full release.
TVRip:
TV episode that is either from Network or from satellite feeds sending the program around to networks a few days earlier.
Unrated / Rated:
VHSRip:
Transferred off a retail VHS.
WP (Workprint):
A workprint is a copy of the film that has not been finished. It can be missing scenes, music, and quality can range from excellent to very poor with 'time bars' on the movie.
WS (WideScreen):
Aspect Ratio Tags.
Watermarks:
A lot of films come from Asian Silvers/PDVD (see below) and these are tagged by the people responsible. Usually with a letter/initials or a little logo, generally in one of the corners. Most famous are the ??Z? ??A? and ??Globe? watermarks.
Asian Silvers / PDVD:
These are films put out by eastern bootleggers, and these are usually bought by some groups to put out as their own. Silvers are very cheap and easily available in a lot of countries, and its easy to put out a release, which is why there are so many in the scene at the moment, mainly from smaller groups who don??t last more than a few releases. PDVDs are the same thing pressed onto a DVD. They have removable subtitles, and the quality is usually better than the silvers. These are ripped like a normal DVD, but usually released as VCD.
Hope this Helps
Very good and informative !! lot of people can use this info.though some of the stuff is missing like DVD XVID,TS XVID etc...
None the less thanks for sharing.
