Definitive Technology Supercube 2000
Upendra16101983
Chicago
Hi All,
I am planning to bring a Definitive Technology Subwoofer (Supercube 2000) from USA.
Has anyone brought the same to India and Using, Need help as there is Voltage and Frequency variation Between US and India.
Please help me if anyone converted the subwoofer from 110v/60hz to 220v/50hz.
Thanks a lot for your help in advance...
Don't you get the sub with selectable voltage switch? If not...then would suggest you contact Audio Excellence India who are dealers in DefTech....they will advise the cost etc which then you can evaluate if it makes sense to cart the same considering all the hurdles of voltage, customs, weight, warranty etc
