Moving to Actives !!!
+1
Try to overcome the room by sitting closer to the speakers and check if toe in works for you
Large rooms are a blessing and a pain..
Those panels spoil the view don't you think ?
Panels does spoil the view but the sound changes completely when they are there. So have convinced Home Ministry about foldable panels ;)
Listening position is the small stool that you see near the carpet :) I can not touch the left wall, I will get killed :p max I can do is removal absorption panel
1. This is from ATC manual. Ensure that your listening position is correct.
2. Bigger ATC i.e. from SCM50 onwards have asymmetric mid & tweeter arrangement. These should be normally positioned on the inside.
"Monitors with an asymmetric (offset) driver array should be positioned such that the midrange driver and tweeter are inboard"- Manual.
For eg:
For eg:
Yes, this how the speakers have been placed.
The ET3 CJ matched very well with the ATCs. It will definitely be a worthy bet to upgrade to ET6 or ET7. GAT is beyond reach :p
@deepestpurple
An older CJ pre/power has come up for sale on the forum
Units are local in Bangalore
Raghu
@deepestpurple
Raghu
Thanks Raghu. I am looking for the higher newer version of CJs pre.
Esoteric is good stuff. D05 should be upgraded to the D02 level whenever possible
Just saw that it’s D05x. That should be good
yes, the DAC is superb. And the transport is mind boggling. If the older model does such a superb job, wonder what the new models will do :) btw it took two folks to bring the transport box. Tried lifting it, 40kg !!!!
Hi @deepestpurple
Lovely speakers there...end game I would say. I've always lusted after the active big ATC's :)
I use a music first passive preamp, with a esoteric k-01. And the transparency and detail resolution have taken on another step. So if you are the kinds, that are into details, and micro nuances, then passive is certainly a good way ahead. But I personally would have added a tube preamp if it was me :D
