Need avr
It will be very difficult to find a 3800 used one. If you come across one, it will be brought to you and cost you the same as a new one. If you are looking for a very budget-friendly option, then I suggest you look at the lower models. 7.2 channels, if you consider Yamaha, could be much cheaper.
