htpc remote in bangalore
doors666
bangalore
does anyone know where can I buy an HTPC remote in bangalore. I am looking for an infrared remote with a transceiver. How much roughly will it cost.
thanx
the only likely place is SJP road. are you running windows or linux? If the latter, almost any remote+transceiver can be used via lirc. If windows media centre, you may have to look for compatible models.
thanx
If you plan on running this off of MS Media Centre Edition then any model of harmony remote should work even though the 680/685 are made for HTPCs. Pair it with one of these as a cheap solution and you are set.
USB-UIRT Home
