Which DAC is better? Denon 2310 or oppo 93
Totally agree with your comment however i couldn't find any wonders what pure direct does though people emphasize it is just a crap, I have connected my tv using toslink, have you experienced the difference in audio from Naka and Denon 2310ci ?
The actual chip, Cirrus/Wolfson/AKG whatever, doesn't matter, they are all very good, and you can't really differentiate between them. What matters is the analog out implementation--just alternate the setups a few times..and see what sounds best to you.
Never use Direct/Pure direct modes on AVRs. What's the point of getting an AVR if you don't employ what is arguably the most important feature of the unit? A majority of what reaches your ears is dictated by your room, so use the room correction processing, unless you've invested heavily in acoustically treating your room of course.
If you absolutely must use Direct, then Denon's do output to SW even in those modes. You just select LFE+MAIN in your setup, while keeping the FL/FR as Large.
