65" 4K Android TV with Dolby Atmos
testlink
Kerala
I am looking for a 65" 4K / QLED TV with good sound that wont require an extra sound bar. At Amazon I can see the below models with inbuilt Dolby Atmos speaker system. Any advice on which one is best value for money? My max budget is 85K. Thanks...
1. Hisense 164 cm (65 inches) 4K Ultra HD Smart Certified Android QLED TV 65U6G (Metal Gray) (2021 Model) | With Dolby Vision and Atmos - Rs. 84,999.00
2. Hisense 164 cm (65 inches) 4K Ultra HD Smart Certified Android LED TV 65A73F (Black) (2021 Model) | With JBL 6 Speaker System | With Dolby Vision and Atmos - Rs. 64,990.00
3. Hisense 177 cm (70 inches) 4K Ultra HD Smart Certified Android LED TV 70A71F (Black) (2021 Model) | With Dolby Vision and ATMOS - Rs. 79,990.00
4. Vu 164cm (65inches) Cinema TV Action Series 4K Ultra HD LED Smart Android TV 65LX (Black) (2021 Model) I With 100 watt Front Soundbar - Rs. 64,999.00
5. Nokia 164 cm (65 inch) Ultra HD (4K) LED Smart Android TV with Sound by Onkyo (65TAUHDN) - Rs. 54,999
6. Blaupunkt Cyber Sound 164 cm (65 inch) Ultra HD (4K) LED Smart Android TV (65CSA7030) - Rs. 54,999
I SUGGEST U BUY HISENSE 70 INCH U CAN BARGAIN FOR 73K FROM RELIANCE DIGITAL AND ALSO GET 2YRS EXTENDED WARRANTY,
Welcome to the forum. Glad to have you here.
Just want to point out that typing in all caps is considered shouting online.
Please refrain from using all caps as it can be taken the wrong way.
is it hearing for the first time, thanks of the info
I might go with Sony Bravia 164 cm (65 inches) 4K Ultra HD Smart LED Google TV KD-65X80AJ (Black) (2021 Model) as it has most of the features I want like Google TV OS, Dolby Atmos, 65" tv size etc.
Any suggestion regarding a Dolby Atmos sound bar around 30 - 40k INR? Go with a sony Sound Bar? Please suggest. Thanks....
While buying a sound bar don’t be giving to much importance for atmos. Get a soundbar that has clear vocals. Check user feedback and reviews on models that have very clear vocals.
I have not auditioned soundbars. I remember once I enjoyed a Yamaha sound bar yas 209 at my cousin sister place. Check out Yamaha and Samsung soundbars within the 30-40k range.
a guy with a 85k tv budget should spend another 40k on a soundbar ?
good advice.
good advice.
Before jumping in to conclusions you better read properly. I have highlighted below why I suggested.
I would suggest you to go with U6G as it has Full array LED. This will give you better picture quality than any other tv below 1 lac . If you are keen on Sony then try x7400 H .
You can go with Blaupunkt, Boat or JBL soundbar. They theoretically decode ATMOS. For little Higher budget you can look at HTIBs from YAMAHA. Also you can try old AVRs for cheap and pair with a 5.0 package from Polk , Taga . Later you can add a sub.
Taga's are value for money and well received from many FMs
If I were constrained by budget, I'd put my money on a VU first, the a Hisense.
I'd ask that you check these TV's out in person before you put down your money. While Android is great on a TV, the underlying hardware that runs the OS is usually poor and that leads to poor response of the interface (if such a thing matters to you).
Nokia or Blaupunkt, please, please stay away. There is a reason why they are priced so cheap. The main business focus of these companies are not TV's. They are selling TV's for the heck of it. Its tragic to see brand a like Blaupunkt selling TV's. Once a pioneer in car radio equipment.
If you can stretch your budget a tiny bit more over, like 12%, you can buy a LG UN73 of the same screen size. Sound is okay. Not great. Wait a while, save up money and buy a decent sound bar or better external speaker system.
