65" for a budget of 1 lac x80j?
Jaiminp
I'm looking for a 65".
Currently have an offer from Reliance digital for 95k ( after cashback) for Sony x80j.
Use is light to medium ott/ normal TV. No gaming.
I have a very bright hall and looking for suggestions accordingly. Viewing distance is 10 ft
Can someone please suggest for the price range.
I think it's a decent tv. If you need better viewing angles, you can go for it as it has an IPS panel and also Android TV is a plus. On the other hand if Android TV dsnt interest you, you can look at Samsung AU8000 as it has better reflection handling than the Sony model plus VA panel would have better black levels. So take the decision going by the room conditions.
