asoft_amit
Hello friends. Greetings for the day.
I am having my HTS. Need some guidance for room acoustics. I have built the room with seforex bricks to cut cost. For floor I will be using normal tiles and then will put felt over it. For sedorex walls I should use wall care or not. And then add panel as and where required.
Suggest me acoustics material
Also my room size is 17x13. So screen should be 9x5, 10x6, 11x6
